Inventor General
Active Member
djh692
Message 1 of 7 (165 Views)
Model Animation
165 Views, 6 Replies
11-25-2013 09:14 AM
I have created a 3D model of a gimble, with a supporting frame, an outer frame rotating about one axis, and another frame rotating withing that on another axis. When I have the assembly in the 'assemble' view, I have defined my constraints and can rotate the outer and inner frames independantly. When I switch to the 'studio' environment and try to animate the assembly, the inner frame can be animated, however the outer frame won't move.
Daniel Hutton
JDMather
Message 2 of 7 (159 Views)
Re: Model Animation
11-25-2013 09:42 AM in reply to: djh692
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
djh692
Message 3 of 7 (155 Views)
Re: Model Animation
11-25-2013 09:49 AM in reply to: JDMather
Ah, I thought that might be the case, i will have to post twice to include all parts
thanks,
daniel
Daniel Hutton
Active Member
djh692
Message 4 of 7 (153 Views)
Re: Model Animation
Active Member
djh692
Message 5 of 7 (150 Views)
Re: Model Animation
11-25-2013 09:50 AM in reply to: JDMather
JDMather
Message 6 of 7 (121 Views)
Re: Model Animation
11-25-2013 11:22 AM in reply to: djh692
I would add angle constraints to control the motion (you won't be able to free drag - but will be able to operate more realistically.
Then I would Animate Constraints the angle constraints.
Better yet -
don't use the angle constraints (although your motor shafts should be connected to frames) and start learning the Environments>Dynamic Simulation.
Active Member
djh692
Message 7 of 7 (118 Views)
Re: Model Animation
11-25-2013 11:23 AM in reply to: JDMather
Much appreciated!
Daniel Hutton
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
