Inventor General
*Hoder, Dave
Message 1 of 16 (185 Views)
Miter Folds
185 Views, 15 Replies
02-12-2003 06:05 AM
Has anyone figured out how to do a miter fold yet? If you don't know what
that is, picture this:
Take a strip of material say 4"x48"x1/2", chamfer the 2 short ends @ 45 deg,
cut 3 45deg v-grooves at equal spacing & leave .030" material at the bottom
of the groove. Now fold the machined part into a rectangle. Maybe one of you
sheet metal gurus can help me here.
Thanx, Dave
*Keller, Kent
Message 2 of 16 (185 Views)
Re: Miter Folds
02-12-2003 06:48 AM in reply to: *Hoder, Dave
I would think it could be modeled without to much hair pulling, but I doubt you will be
able to unfold it.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Dave Hoder" wrote in message
news:963038B2A0AF04CE775DF5DE9F07DA28@in.WebX.maYIadrTaRb...
> Thanx, Dave
*Hoder, Dave
Message 3 of 16 (185 Views)
Re:
02-12-2003 07:37 AM in reply to: *Hoder, Dave
I need to show it as one part (with the original part size) in the BOM &
unfold it for machining. Right now I'm faking it by making a drived part
from a dummy unfolded assy & hiding the separate parts in the Parts List.
This won't be a good idea though as soon as we start pulling data directly
from assemblies. Any ideas?
*Bliss, Charles
Message 4 of 16 (185 Views)
Re: Miter Folds
02-12-2003 11:46 AM in reply to: *Hoder, Dave
Create flanges using the offset option. make the offset longer then the
flange width. This will leave large gaps between your flanges. Use the
corner tool to close the flanges. This will give you a mitered corner.
I have placed an example in Customer Files.
>Thanx, Dave
*Keller, Kent
Message 5 of 16 (185 Views)
Re:
02-12-2003 01:12 PM in reply to: *Hoder, Dave
I could easily be wrong, but I don't think that is what he is after. The
words 45deg v-groves and Machined parts makes me think he wants a weakening
grove to make the fold with.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
"Charles Bliss" wrote in message
news:3E4B1502.5000604@cbliss.com...
deg,
bottom
*Hendey, Matt
Message 6 of 16 (185 Views)
Re: Miter Folds
02-12-2003 08:38 PM in reply to: *Hoder, Dave
Can you post what you have in CF?
Matt
*Keller, Kent
Message 7 of 16 (185 Views)
Re:
02-13-2003 01:11 AM in reply to: *Hoder, Dave
Matt
If you are talking to Charles... He did! 8^)
Kent
"Matt Hendey" wrote in message
news:f1431d6.4@WebX.maYIadrTaRb...
> Matt
*Hendey, Matt
Message 8 of 16 (185 Views)
Re:
02-13-2003 03:10 AM in reply to: *Hoder, Dave
No to Dave, Sorry. I'm interested in what he is trying to do. I tried
creating the part from the description he gave but if I got it right, I
can't see the reason for building a part that way. No that there isn't one.
Matt
"Kent Keller" wrote in message
news:1B117C461A3FF93F56B7ACC5468940BB@in.WebX.maYIadrTaRb...
> Matt
> Kent
> > Matt
*Hoder, Dave
Message 9 of 16 (185 Views)
Re:
02-14-2003 12:46 AM in reply to: *Hoder, Dave
The part is in CF called Miter Fold. (I just made an example shape, not a
sheet metal part) This is a common manufacturing process in the furniture /
woodworking industry where we are working with a piece of wood covered with
a colored paper. We cut thru the wood & leave the paper, then fold the whole
thing together. This makes for a cleaner seam & less assemby time.
Thanks for having a look.
*Caldwell, Larry
Message 10 of 16 (185 Views)
Re:
02-14-2003 12:53 AM in reply to: *Hoder, Dave
I did one of those by ... cheating? ... making a face that would bend then
add the rest in an assembly because it needed to be shown both flat and
folded.
~Larry
news:F82FB0D513739B07DFE1A95A4327C751@in.WebX.maYIadrTaRb...
with
whole
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
