I have a template IDW that i use for bearings. When I opened it today I noticed that two of the dimension lines were missing. The dimension and arrows are there. I tried deleting them are recreating them with the same result.
The interesting thing is, when I created the dim above the part it was fine, when I dragged it below the part the lines went away. After that no matter were I moved it the lines would not reappear.
I installed SP1 a while ago and just now installed the update to SP1 (DL20857064.zip). It did not fix the problem.
Any ideas on what is causing this?
