I am at a loss here 😞 I have been putting centerlines on a lot of circles but all of a sudden this started happening. Can you tell me how to get the one centerline back?
Thank you for your help,
Angela
Solved by Cadmanto. Go to Solution.
When you placed this centermark, was the object you selected a complete circle or a radius? If it is a radius, then I can see it giving you these results. If it is a circle then I have to ask if this is the on;y drawing this is doing it on? Maybe a graphics issue?
Also, can you grab the stub end and drag it to 12 o'clock?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
hhhmmmm - it's an arc - so that solves that question LOL. I thought it was detailed as a circle. Thank you so much!
Angela
