Show only
Search instead for
I have a huge problem with Inventor and Vault on one of our computers. I can't log in to Vault because the command is not loaded! The add in for Vault is loaded but still no command. Other Vault commands is in place. See attached picture.
As you can see in the screen shoot, the commando missing (not grayed out). But I found a way. Inventor is for som reason not showing all the Add-ins and I had to right click in the list and choose "Show hidden members". The add in called EDM addin was not loaded. After loading this everything was back to normal.
Some question to Autodesk: User started Inventor an no add-ins was loaded at all! I loaded them for him and everything was fine. Why did the add-ins suddenly stop loading? Why did I have to log in as an administrator to tick the mark: Load on startup?
Right, the Vault Log In/Out is controlled by this hidden EDM addin. To be honest, it should be loaded by default for the first launch of Inventor. I have no chance to get into your issue that the addin stops loading all of a sudden. However, the addin load status is stored in the register which cannot be changed unless the user is with administrative permissions.
