Inventor General
New Member
Message 1 of 4 (218 Views)
Missing Ribbon text.
218 Views, 3 Replies
05-03-2012 08:15 PM
Theres no text on the ribbon bar. So far, I have tried switching from classic to ribbon UI, changed the font size from the application options, reinstalled and uninstalled twice, cleaned my PC of registry errors, system restored to the time i didnt have this problem. Googled for a week for solutions but still havent found one. Please help me
Valued Contributor
Message 2 of 4 (207 Views)
Re: Missing Ribbon text.
05-04-2012 06:49 AM in reply to: xezzbeth
xezzbeth,
Check out the following link. I had the same trouble awhile back.
http://forums.autodesk.com/t5/Autodesk-Inventor/Missing-font-squares-in-all-Inventor-menus/m-p/32070...
HTH,
Todd
New Member
Message 3 of 4 (195 Views)
05-05-2012 01:34 AM in reply to: xezzbeth
hey todd,
how do i create a new profile? i made a new profile/user account on my pc. then ran inventor, it still has the same issue. should i delete something?
Valued Contributor
Message 4 of 4 (179 Views)
05-07-2012 03:27 AM in reply to: xezzbeth
xezzbeth,
Sounds like you created a new profile alright, could be an installation problem. Did you look at the thread that was linked to the one above?
http://forums.autodesk.com/t5/Autodesk-Inventor/blank-ribbon-amp-no-text-in-Inventor-screen/m-p/2898...
There are some good ideas there as well. Has IV worked before or is this a new installation? You should probably list your computer specs here so others on here may be able to help. I'm afraid I can't be of any more help. Good luck!
Todd
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
