Inventor Forum
Missing Pattern Dialogue In Mould Design
11 REPLIES 11
Message 1 of 12
cmharb
939 Views, 11 Replies
Inventor Pro 2013 SP 1.1
Hi, I’m suing the Mould Design feature of Inventor Professional and need to have four cavities for this mould. When I try to use the pattern function nothing happens. I look at the Wiki help and it says that I have to enter values for X direction X distance etc, but this dialogue box does not appear.
How can I get the box to appear?
Thanks in Advance.
w7u-64sp1,iv14,intel.xeon.e5-2620 0 @2.00 2.00-32gb,gtx560-4gb
11 REPLIES 11
Message 2 of 12
JDMather
in reply to: cmharb
Does it work when you do the Tutorial?
The CADWhisperer YouTube Channel
Message 3 of 12
MingweiGao
in reply to: cmharb
Can you see Pattern command from the attached picture?  I also installed 2013 SP1.1 and have this command.
Steven Gao
Sr. SQA Engineer
Message 4 of 12
cmharb
in reply to: MingweiGao
i do not see the Pattern box like that.
Message 5 of 12
cmharb
in reply to: JDMather
no have not done the Tutorial , I'Il do them now and see if it makes a differnace.
Message 6 of 12
cmharb
no,  i get to
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0807-Tooling_807/0826-Family_M8...
in the tutorial and there is not Pattern box, it might be off the screen.
Anyone know how to get it back?
Message 7 of 12
JDMather
in reply to: cmharb
@cmharb wrote:
... there is not Pattern box, it might be off the screen.
You don't see the dialog box... ... but do you see the tool on your screen?
Message 8 of 12
cmharb
yes the mouse is a selector and i can sellect a plastic part. But the box for editing the pattern details is missing.
Message 9 of 12
Curtis_Waguespack
in reply to: cmharb
Hi cmharb,
How to get a missing dialog box back:
  • start the tool that exhibits the problem
  • press ALT + Space-bar on the keyboard
  • then press the M key (M for move)
This is what happens off screen
  • then Immediately press any of the arrow keys on the keyboard
  • finally, move your mouse around and the dialog box will now be attached to your cursor allowing you to drag it back on screen, just click to drop it in place.
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
Message 10 of 12
cmharb
in reply to: cmharb
Message 11 of 12
MingweiGao
in reply to: cmharb
It seems the dialog out of the screen.  Can you have a try to adjust your screen resolution to lower, such as 1680x1050?
Steven Gao
Sr. SQA Engineer
Message 12 of 12
cmharb
Thanks for all your help
The Alt-Space >m arrows keys fixed it.
