Inventor Pro 2013 SP 1.1
Hi, I’m suing the Mould Design feature of Inventor Professional and need to have four cavities for this mould. When I try to use the pattern function nothing happens. I look at the Wiki help and it says that I have to enter values for X direction X distance etc, but this dialogue box does not appear.
How can I get the box to appear?
Thanks in Advance.
Solved by Curtis_Waguespack. Go to Solution.
Does it work when you do the Tutorial?
Can you see Pattern command from the attached picture? I also installed 2013 SP1.1 and have this command.
i do not see the Pattern box like that.
no have not done the Tutorial , I'Il do them now and see if it makes a differnace.
no, i get to
in the tutorial and there is not Pattern box, it might be off the screen.
Anyone know how to get it back?
@cmharb wrote:... there is not Pattern box, it might be off the screen.
You don't see the dialog box... ... but do you see the tool on your screen?
yes the mouse is a selector and i can sellect a plastic part. But the box for editing the pattern details is missing.
Hi cmharb,
How to get a missing dialog box back:
This is what happens off screen |
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
It seems the dialog out of the screen. Can you have a try to adjust your screen resolution to lower, such as 1680x1050?
Thanks for all your help
The Alt-Space >m arrows keys fixed it.
