I'm having problems with the parameter menu. When I don't have a user parameter linked to a dimension in the model the parameter disappears out of the parameter menu. Does any one know the reason this is happening and how I can fix it.
Solved by torbjorn. Go to Solution.
Check the filter settings in the parameters dialog (The funnel in the lower left corner). It seems to behave as if the 'equation' filter was selected.
