Inventor General
zetex
Message 1 of 8 (278 Views)
Mirrored Part
278 Views, 7 Replies
12-03-2013 01:50 PM
Why when I mirror a part in an assembly the mirrored part gets a new part number? I want to mirror only the position of the part which is always the same part. Is it possible to do that in Inventor?
JDMather
Message 2 of 8 (272 Views)
Re: Mirrored Part
12-03-2013 02:26 PM in reply to: zetex
What options do you have selected?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
zetex
Message 3 of 8 (269 Views)
Re: Mirrored Part
12-03-2013 02:29 PM in reply to: JDMather
Under Assemble ribbon "Mirror" command
JDMather
Message 4 of 8 (255 Views)
Re: Mirrored Part
12-03-2013 03:24 PM in reply to: zetex
That is the command you used - not the options of the command.
I am not at an Inventor computer right now, but start the command and experiment with the various options.
Also I recommend goingthrough the tutorials and check the help system.
Employee
t_stramr
Message 5 of 8 (211 Views)
Re: Mirrored Part
12-18-2013 05:46 AM in reply to: zetex
Hi zetex,
Assembly Mirror command works in two modes.
The first mode we call "True Mirror" and is represented by GREEN icon in mirror dialog box. In this case, selected component is mirrored using derive mechanism to create completely new part and instrance of this new part is placed at target position.
The second mode is called "Reuse" and is represnted by yellow icon. In this case, we only place new instance of selected component and the command is trying to define target poistion and orientation so the new instance will look like mirrored.
Both these modes remain source component unchanged, so it is not moved or removed.
Robert
zetex
Message 6 of 8 (194 Views)
Re: Mirrored Part
12-18-2013 10:44 AM in reply to: t_stramr
Thanks Robert, that was doing great!:smileyhappy:
zetex
Message 7 of 8 (149 Views)
Re: Mirrored Part
12-19-2013 01:54 PM in reply to: zetex
There is a problem with that solution: the mirrored parts keeping the origin part number are not constrained at all, so I have to constrain them one by one....:smileyfrustrated:
Employee
t_stramr
Message 8 of 8 (93 Views)
Re: Mirrored Part
01-07-2014 12:34 AM in reply to: zetex
Can you post simplified version(ZIP file) of your dataset so I can try it on my machine?
Robert
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
