Inventor Forum
Mirrored Part
7 REPLIES 7
Message 1 of 8
808 Views, 7 Replies
Mirrored Part
Why when I mirror a part in an assembly the mirrored part gets a new part number? I want to mirror only the position of the part which is always the same part. Is it possible to do that in Inventor?
7 REPLIES 7
Message 2 of 8
JDMather
What options do you have selected?
Message 3 of 8
in reply to: JDMather
Under Assemble ribbon "Mirror" command
Message 4 of 8
JDMather
That is the command you used - not the options of the command.
I am not at an Inventor computer right now, but start the command and experiment with the various options.
Also I recommend goingthrough the tutorials and check the help system.
Message 5 of 8
t_stramr
Hi zetex,
Assembly Mirror command works in two modes.
The first mode we call "True Mirror" and is represented by GREEN icon in mirror dialog box. In this case, selected component is mirrored using derive mechanism to create completely new part and instrance of this new part is placed at target position.
The second mode is called "Reuse" and is represnted by yellow icon. In this case, we only place new instance of selected component and the command is trying to define target poistion and orientation so the new instance will look like mirrored.
Both these modes remain source component unchanged, so it is not moved or removed.
Robert
Message 6 of 8
in reply to: t_stramr
Thanks Robert, that was doing great!Smiley Happy
Message 7 of 8
There is a problem with that solution: the mirrored parts keeping the origin part number are not constrained at all, so I have to constrain them one by one....Smiley Frustrated
Message 8 of 8
t_stramr
Can you post simplified version(ZIP file) of your dataset so I can try it on my machine?
Robert
