Inventor Forum
Mirror tool accuracy
5 REPLIES 5
LeedsLad8t6
275 Views, 5 Replies
Hello all, Does anybody else have slight inaccuracy's with the mirror tool every now and again? I find sometimes when trying to mirror features that they do not measure exactly on each side, the difference is tiny! but it's still there when you inspect the length... When I have encountered this in the past I have been mirroring from planes center to the part, I can't fathom it out or repeat the issue on demand. It just seems to crop up every now and again 😕 Kind regards Daniel
5 REPLIES 5
chad38
in reply to: LeedsLad8t6
Are you certain it's not related to rounding of the digits? For instance 7/16 rounded to 3 digits can be displayed as .437 or .438.
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
LeedsLad8t6
in reply to: chad38
Thank's for your reply, hadn't thought of that although this issue involved straight edges only. I have re attempted and solved the issue, what I did wrong to begin with I'm not quite sure 😕 Thanks. Daniel
MikahB
Daniel - did you notice if you click "More >>" at the bottom of the mirror dialog there are a couple options on how the mirror is performed? I think it defaults to "Identical" but maybe yours is on "Optimized" or "Adjust."
Mikah Barnett
All Angles Design
Product Design Suite Ultimate 2014
Windows 7 Professional x64
Intel i7-3770k @ 4.5GHz
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
LeedsLad8t6
in reply to: MikahB
I did not know that no, I will have a look at this in more detial. Thanks Daniel
blair
Since IV runs to something like 13 decimal places, as in the previous post, check your rounding. In the Document settings, you might have the sketch options set to only 2 decimal places. I set this to 4 places as I want my fractions to stay as fractions. 3/16" will stay at 0.1875" and not round up to 0.188 or 0.19
Delta Tau Chi ΔΤΧ
