Inventor Forum
Mirror glitch
1 REPLY 1
336 Views, 1 Reply
Mirror glitch
I'm mirroring an ipart over the xy plane, and the preview looks perfect.  However, when I click "ok" on the Mirror Components: File Names dialog, the new mirrored part appears next to the original part.  The mirror itself is correct, along with orientation, but the placement is wrong.
What am I missing?
Also, once I actually get the mirror to work, is there a way to get the ipart mirror to be driven to match the different configurations of the original ipart in its iassambly?
Or would it be best to turn the mirror into its own ipart and manage it independantly? Ideas?
Tags (1)
1 REPLY 1
t_stramr
Hi eveylynne,
I'm one of developers responsible for mirror command. From attached pictures I can't say what is wrong. From captured view I don't even see the mirror plane. If it is possible please attach your dataset in ZIP form. Simplified dataset(remove all components that are not included in mirror) where the problem is still reproducible is the best choice.
Q1: Once you modify iPart table and update your source iPart then its mirrored counterpart should be updated as well as it is mirrored using derive mechanism.
Robert
