Inventor Forum
Mirror Components???
6 REPLIES 6
403 Views, 6 Replies
Can you mirror components in an assembly? I've not
found that you can. Pattern arrays are okay, but not always
practical. And if not has anyone heard anything about this being a future
option?
Also I sure do miss the old AutoCAD stretch command.
Thanks, Joseph
6 REPLIES 6
About all I think you can do is derive them into a new file and use the
mirror option. Then insert that new file.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Joseph Shelton" wrote in message
news:B269F43F493E9A16629F0F00B83E6C60@in.WebX.maYIadrTaRb...
> Hi,
> option?
> Thanks, Joseph
Create a new part and derive w/ mirror option is the only way that I have found.
Why can't you still stretch? You may not be able to stretch with a crossing
window, but just click (and hold) any sketched object and you can drag
anywhere (depending on constraints) you want.
kevin
> Hi,
> option?
> Thanks, Joseph
True, but I have also wished for a stretch since I started working with solid modelers.
Actually the old TriSpectives came close, as does the base solid modeling tools in
Inventor.
I think the stretch Joseph and I are thinking of is of the solid model, not sketches. Run
a crossing window over the solid and input a distance, and it takes care of all the
underlying dimensions. If a dimension lies inside of the crossing window then it doesn't
change, but if it crosses the window then its value is increased the proper amount. I
suppose doing it at sketch level could even really speed things up, but I have always
envisioned it in the solid.
Kent
"Kevin Snyder" wrote in message
news:E3B9202DBD8C51D89AA6AE2CCE2F6672@in.WebX.maYIadrTaRb...
> kevin
It is true you stretch in the sketch environment, however I would like to
stretch
in the model environment. i.e.. . You have a machine station and need to
change
the elevation. It would be nice to be able to just stretch the assembly
causing components
to update.
Joseph
crossing
> kevin
> > Hi,
future
> > option?
> > Thanks, Joseph
Investigate adaptivity (or skeletal modeling) If you set up the
relationships correctly you can change one workplane (effectively stretching
the assembly) and parts will adapt to the new size.
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
news:46662F52E6F484A4A74EA83021BAACBD@in.WebX.maYIadrTaRb...
> Hi,
> stretch
> change
> causing components
> to update.
> Joseph
> crossing
> > kevin
> > > Hi,
> future
> > > option?
> > > Thanks, Joseph
