Inventor General
Member
sweeneym
Message 1 of 7 (175 Views)
Minimum dimensions needed
175 Views, 6 Replies
04-03-2012 12:57 PM
All of the sudden after I sketch a rectangle i need 8 dimensions instead of 4.  how do I get it back to only needing 4?
Valued Contributor
schae235
Message 2 of 7 (171 Views)
Re: Minimum dimensions needed
04-03-2012 01:03 PM in reply to: sweeneym
I'm only guessing here but I think you had one of the end points constrained to the origin.
You can easily add a coincident constraint on one of the corners
OR as I prefer add horizontal and vertical constraints to the center marks of the lines of the rectangles.
INV 2012 SP1
Windows 7 64 Bit
ATI FirePro V5800
14.0 GB RAM
Member
sweeneym
Message 3 of 7 (159 Views)
04-03-2012 01:10 PM in reply to: schae235
No I always draw teh rectangles like this then add 4 dimensions the horizontal and vertical overall lengths then distacnce to center. Now it wants me to constrain the 2 vertical and 2 horizontal lines. as well as dimensioning the lines.
Active Contributor
Accudyne1
Message 4 of 7 (156 Views)
04-03-2012 01:13 PM in reply to: sweeneym
Did these get turned off?
Member
sweeneym
Message 5 of 7 (133 Views)
04-03-2012 01:28 PM in reply to: Accudyne1
Accudyne1, I couldn't reall read your screen shot here but with me switching back and forth from classic to ribbon interface style the problem was fixed.
Active Contributor
Accudyne1
Message 6 of 7 (129 Views)
04-03-2012 01:29 PM in reply to: sweeneym
The actual image was attached also, but glad you fixed it.  I am guessing it was constraint inference/persistence.  They must have gotten toggled off at some point.
Tony
Member
sweeneym
Message 7 of 7 (117 Views)
04-03-2012 01:32 PM in reply to: sweeneym
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
