style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"TC" <1john@liftaloft.com>What
wrote in message
href="news:f12bf9d.-1@WebX.maYIadrTaRb">news:f12bf9d.-1@WebX.maYIadrTaRb...
the is going on. I can't seem to migrate from 5.3 to 6. use the inv 6
migration program and on one computer it frezzes after doing 6 files and the
other computer freezes after doing 8 files. i have tried everything but still
no luck. this is keeping me from getting any work done at all. have
over 3,000 files i need to migrate. does anyone know how to fix this? i have
already reinstalled inv 6 and all that crap that you shouldn't have to do all
the time. ps i had not one problem going from 5.0 to 5.3.
1.9 p4
1.3 g ram
ati video
40 g hd
winn 2000
pro
"TC" <1john@liftaloft.com>The
wrote in message
href="news:f12bf9d.3@WebX.maYIadrTaRb">news:f12bf9d.3@WebX.maYIadrTaRb...
files i started with were just steel shapes at different lengths. one comp
freezes after doing 6 files
and the other after 8. i haven't even got to
the large files
of unit assemblies or weldments yet. right now just trying
to do steel shapes and fastners. you can have the same part
saved as 7
different names and it will freeze up after trying to migrate the 6th one
every time. i let it set for over an hour and
nothing.....
wrote in message
the large files
saved as 7
nothing.....
"KJohnson" <kj@sensoft> wrote in
message
href="news:146F51829BBC3B107CEA4A7C9FA5A632@in.WebX.maYIadrTaRb">news:146F51829BBC3B107CEA4A7C9FA......
I think someone from autodesk suggested changing
the hardware acceleration to Microsoft generic (lowest setting) then running
the utility. Has to be worth a try. It did work on one of my
assemblies.
Kathy Johnson
"TC" <The
href="mailto:1john@liftaloft.com">1john@liftaloft.com> wrote in
message
the large files
trying to do steel shapes and fastners. you can have the same part
saved
as 7 different names and it will freeze up after trying to migrate the 6th
one every time. i let it set for over an hour and
nothing.....
wrote in message
1.9 p4
1.3 g ram
ati video
40 g hd
winn 2000
pro
"Sean Dotson" <sean at sdotson dot com> a écrit dans le message de
news:
href="mailto:1C6D7282B0FBE9B6BE6374363F713CB5@in.WebX.maYIadrTaRb">1C6D7282B0FBE9B6BE6374363F713C......
If this is true then this may be his
problem. Notice the first post. ATI video card..
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
message
href="news:146F51829BBC3B107CEA4A7C9FA5A632@in.WebX.maYIadrTaRb">news:146F51829BBC3B107CEA4A7C9......
changing the hardware acceleration to Microsoft generic (lowest setting)
then running the utility. Has to be worth a try. It did work on
one of my assemblies.
Kathy Johnson
"TC" <The
message
to the large files
saved as 7 different names and it will freeze up after trying to
migrate the 6th one every time. i let it set for over an hour and
nothing.....
"Dominique >" <<nospam> wrote in message
href="news:3E9A23312589AEA72E98A5EBFC49AD2A@in.WebX.maYIadrTaRb">news:3E9A23312589AEA72E98A5EBFC4......
I don't understand why the video setting is
important. When inventor migrate the files with the migrate tools,
inventor is not open on the screen...
I have migrate all of my files.
3000 ipt files in 8 hours .....P4, 1,7 Ghz, 512
MB RAM
de news:
href="mailto:1C6D7282B0FBE9B6BE6374363F713CB5@in.WebX.maYIadrTaRb">1C6D7282B0FBE9B6BE6374363F71......
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
in message
href="news:146F51829BBC3B107CEA4A7C9FA5A632@in.WebX.maYIadrTaRb">news:146F51829BBC3B107CEA4A7......
on one of my assemblies.
Kathy Johnson
"TC" <The
message
comp freezes after doing 6 files
even got to the large files
right now just trying to do steel shapes and fastners. you can have the
same part
trying to migrate the 6th one every time. i let it set for over an hour
and
nothing.....
"Albert Allen" <
href="mailto:albert@sno-cat.com">albert@sno-cat.com> a écrit dans le
message de news:
href="mailto:DBFE86575D65CB35CB890E8ACCCEAE30@in.WebX.maYIadrTaRb">DBFE86575D65CB35CB890E8ACCCEAE......
As far as I can tell Inventor opens up for each
migration and if Inventor is on then video is important.
href="news:3E9A23312589AEA72E98A5EBFC49AD2A@in.WebX.maYIadrTaRb">news:3E9A23312589AEA72E98A5EBF......
MB RAM
de news:
href="mailto:1C6D7282B0FBE9B6BE6374363F713CB5@in.WebX.maYIadrTaRb">1C6D7282B0FBE9B6BE6374363F......
Sean Dotson, PE
Check the
in message
href="news:146F51829BBC3B107CEA4A7C9FA5A632@in.WebX.maYIadrTaRb">news:146F51829BBC3B107CEA4......
Kathy Johnson
"TC" <The
message
the same part
after trying to migrate the 6th one every time. i let it set for over
an hour and
nothing.....
