Inventor General
Active Contributor
eucci
Message 1 of 3 (168 Views)
Microstation 3D model to Inventor workflow
168 Views, 2 Replies
01-30-2014 08:14 AM
If anyone has some insight/experience with converting 3d models from Microstation for use in Inventor I'd appreciate any help I can get.
I'm working on a portion of a large civil job (subway station) that was modeled in microstataion. So far, they sent me a massive .iges file that I can import into inventor. Unfortunately, the solid objects are deformed and dimensionally innacurate after the conversion. Does anyone know what the best filetype is for this sort of conversion? My understanding is that I should ask for parasolids (binary .x_b or text .x_t). Is there a preference with binary compared to text?
So far we're speaking different languages and not making any progress.
Any help would be appreciated.
thanks
*Expert Elite*
JDMather
Message 2 of 3 (161 Views)
Re: Microstation 3D model to Inventor workflow
01-30-2014 08:45 AM in reply to: eucci
When opening the IGES be sure to select Options and turn off any healing/quality check/autostitching as this might change the geometry.
I thing the only thing different with the Parasolid is human readable text code or not (and of course file size).  I would opt for the binary.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
mcgyvr
Message 3 of 3 (143 Views)
01-30-2014 10:26 AM in reply to: JDMather
I use STEP (stp) as my neutral 3d format of choice instead of IGES.. I've had problems with iges in the past..Switched to STEP and never looked back..
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
