Hi all,
what am i doing wrong. Afther finishing a part in Inventor 2014 a want to store it as a STL file. Thats no problem but when the part is saved as STL it messurments don't add up any more. The STL file becomes a factor 10 smaller. So 50mm ends up as 5mm. So thats a problem. Does anyone know what is going wrong.
Thanks, Rene The Ntherlands.
You title says STEP, not stl.
When Save Copy as type *.stl be sure to set Options the correct Units (same as model).
How are you checking the resulting size?
Attach the ipt file here.
Zip and Attach the stl file here.
