I've tried it with this file:
https://grabcad.com/library/cnc-boring-1/files/CNC%20Boring.cgr
It's a CATIA CGR file. It can be imported into 2014, but Mesh Enabler took a long time in converting the mesh members to solids. In the end, I gave up.
Next attempt: Selecting only some meshes, converting them, saving them as a separate file, saving new file without them, and doing similar with the remaining meshes.
Normally no bad idea. But as can be seen in the screenshot, filesize is increasing over and over, even with less and less remaining meshes.
😉 What's going on here? Thanks for hints.
Walter
Walter Holzwarth
Hi Rocky,
the CGR filesize is about 34 MB, no attachment is possible. But I'm in doubt, if your answer is correct. As can be seen at the screenshot, 2.8 millions of triangles were converted into an IPT with about 202 MB.
As mentioned earlier, I've tried to reduce filesize by splitting up into smaller sub-assemblies. But each split increased the remaining filesize. For example, CNC Boring_4. ipt has only 5 bodies left, but results in a 286 MB file.
IMO, this isn't logical.
Walter
Walter Holzwarth
Hi Walter,
The huge numbers of faces will cause the file size increase a lot, in Inventor if you directly create a model with the same number of faces you can see the file size is similar, if we can optimize the mesh enabler to reduce the generated faces count then we can reduce the file size. An idea is that if the mesh enabler can recognize the triangles which indicates a cylindrical/sphererical face that we can just generate one cylindrical/sphererical face which will reduce the generated face count a lot, but current mesh enabler could not recognize the faces:(, and it should be very difficulty to implement this also.
