Inventor Forum
Measure
6 REPLIES 6
CAD-One
638 Views, 6 Replies
Measure
Can we use measure tool without having to open the part file?
Say directly in the viewer or in vault viewer.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
6 REPLIES 6
mcgyvr
in reply to: CAD-One
Don't use vault but the Inventor Viewer does NOT include measurement capabilities (I'd suspect the Vault one doesn't either).. But Design Review does. (of course that also requires DWF files to be created.)
Autodesk has done this simply to increase sales of their products. No matter what they say. 🙂
CAD-One
in reply to: mcgyvr
I totally agree with you. Why keep 2 kinds of viwers. merge them & keep one.
Whats the point in simply looking at a 3dmodel in a viewer. one should be ble to measure too.Measure wouldnt modify nothing. So should be encouraged to have it in viewer.
C1
AutoCAD 2020
bobvdd
There is an Apprentice sample app that is delivered as part of the SDK folder and that has measuring capabilities.
It is a pretty crude viewer (you can rotate but not zoom Smiley Sad)  but we offer the source code so you can always enhance it if you have C++ skills.
To get the app when you have already Inventor installedp, you have to install thedeveloper tools
C:\Users\Public\Documents\Autodesk\Inventor 2013\SDK\DeveloperTools.msi
Once the developer tools are installed, you can access the app in this default location
C:\Users\Public\Documents\Autodesk\Inventor 2013\SDK\DeveloperTools\Samples\VC++\Standalone Applications\ApprenticeServer\CurvatureApp
Because the app  uses the Apprentice API you can install and run the app on any machine that has the Inventor viewer product  installed and you don't need an Inventor license.
Bob
Bob Van der Donck
Principal UX designer DMG group
eDrawings  2013 for Inventor from SolidWorks 2013 will open inventor files and it has a measure tool. We are having the same problem and are going to use the SolidWorks solution. But it is not free. Infact, it is expensive but it is cheaper than full copies of Inventor just so people can measure and less hassle than creating DWF files to open in Design Review. Competition is good. If enough people tell their vendors that they are using the competitions products to fill a gap left by Autodesk, then maybe Autodesk will step up. They are a business... I don't give what I do away for free.
in reply to: bobvdd
I use Inventor 14. When I try to install developer tools it says "Could not find any version of microsoft visual studio." How would I try out the Apprentice app using my version?
mcgyvr
One might deduce that you would need to install Visual Studio...
