Hi there,
Now I am trying to draw 2 hemisphere structures which have a hall and a pillar (bumo) like in the appended file.
Even though I used 2 rectangular parallelepiped in that, I like to use hemisphere.
1) How can I divide a sphere into two parts?
2) How can I make them aprat to make a hall and a pillar? I like to know how I can control them separately after separation.
3) Is there other way except 1) and 2) to make my model?
4) Is there a way to make one hemisphere? I think that I can use "draw sphere -> make workplane at the center of the sphere -> extrude cut half of the sphere".
Is there other ways?
Thanks for reading.
Best,
Hojeong Yu
(I used inventor pro 2014)
Hi!
You can achieve the "half sphere" by several methods:
But... i think these are separate parts, why don't you create them separately and place all of them in a assembly?
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Are you sure you attached the correct file here?
When you create solid bodies the New Solid might be another technique.
