Inventor Forum
Material properties for glass (tempered?) and wood (pine?)
3 REPLIES 3
1178 Views, 3 Replies
Does anyone have this, and also texture for pine (or iPart for lumber with
material and texture already setup)?
3 REPLIES 3
All you really need for Inventor is the density..
which for tempered glass ranges from 0.090 - 0.080 lbs/in^3
The follow values range quite a bit for glass as it varies in quality but
these are good average numbers
Mod of Elasticity = 9.6E6 PSI
Mod of Rigidity =4.1E6 PSI
Ultimate Compressive Strength = 7ksi
Coeff of Thermal Expan = 44e-6/deg F
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Almir" wrote in message
news:61726DF5D864BB0CF546A10D69C658C4@in.WebX.maYIadrTaRb...
> Thanks
Have you looked here
http://www.cbliss.com/inventor/Textures/default.htm
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
> Thanks
www.matweb.com is always a good place to start.
