All you really need for Inventor is the density..
which for tempered glass ranges from 0.090 - 0.080 lbs/in^3
The follow values range quite a bit for glass as it varies in quality but
these are good average numbers
Mod of Elasticity = 9.6E6 PSI
Mod of Rigidity =4.1E6 PSI
Ultimate Compressive Strength = 7ksi
Coeff of Thermal Expan = 44e-6/deg F
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Almir"
wrote in message
news:61726DF5D864BB0CF546A10D69C658C4@in.WebX.maYIadrTaRb...
> Does anyone have this, and also texture for pine (or iPart for lumber with
> material and texture already setup)?
> Thanks
