An M33 is a Metric Coarse Thread with a Pitch of 3.5mm Core Dia of 27.706mm Thread Depth 2.1470 Tapping Drill of 26.5mm Clearance of 33.5mm Not a Metric Fine as you seem to be indicating but even then there is is NOT a Metric Fine or Metric Standard thread of 33mm with the pitch of 1.5mm
The nearest M Fine is 30mm, Pitch 2mm Core 32.319mm Tapping Drill of 32.75mm
ALL size are taken From the UK issue of Zuse Data Charts, a copy of these data charts has been posted here https://skydrive.live.com/#cid=30A7361EF9C3AE77&id=30A7361EF9C3AE77%21496
Just answerthe stupuid question i have been trying to figure this out forever. We just want to know if an 8mm hole threaded with the reccomended metric thread will align with a 8mm rod with its own reccomended metric thread. Or if sizing of either holed needs to be adjusted for a proper fit.
please
@josh92brown wrote:
...We just want to know if an 8mm hole... ...will align with a 8mm rod with its own reccomended metric thread. .
An 8mm rod with pass through an 8mm hole - no thread engagement.
Can you attach your files here - I can demonstrate proper thread fit.
(indicate your manufacturing process)
The CADWhisperer YouTube Channel
Hi Paul,
It is not exactly true. The standard fine pitch for the M33 thread goes for 3 mm, 2 mm, 1.5 mm 1 mm and 0.75 mm.
Here is a quick link to a table showing M33 x 1.5 thread definition. http://mdmetric.com/tech/thddat4.htm
If need be - I can spend some more time on the net and find a Standard which defines all of them.
Igor.
@Paul-Mason wrote:An M33 is a Metric Coarse Thread with a Pitch of 3.5mm Core Dia of 27.706mm Thread Depth 2.1470 Tapping Drill of 26.5mm Clearance of 33.5mm Not a Metric Fine as you seem to be indicating but even then there is is NOT a Metric Fine or Metric Standard thread of 33mm with the pitch of 1.5mm
Typically one might look at a thread chart that shows a min and max diameter.
example...http://www.engineersedge.com/screw_threads_chart.htm
http://www.pencomsf.com/screws-categories/screw-design-guide/
@mcgyvr wrote:
Typically one might look at a thread chart ....
Old-timers keep a Machinery's Handbook reference nearby.
The question arises though, if these are going to be milled (turned?) are modeled threads really needed. I would normally use cosmetic threads and specify the nomenclature on the drawing. The only time I model threads is when it is a particularly large part (not a standard fastener) or if I am going to 3D print. 3D printing involves special considerations - which is why I asked about the manufacturing process.
In any case, I don't see the promised part file attachments.
I actually wrote that the Machinery's Handbook is a great reference to have on hand but then thought these youngsters would want a link to something on the internet. I love that book and use it all the time.. Still using the 24th edition here..
@mcgyvr wrote:
@mcgyvr wrote:
...these youngsters would want a link to something on the internet. I love that book ...
Book? What is this artifact that you refer to as "book".
@Anonymous wrote:
I've actually got the 11th edition too from 1942 in pristine condition.. I wonder if its worth anything.. (edit.. nope.. looks like its going for $10 to $65 or so on ebay)
DUH read the charts that I posted the link to
THEY TELL YOU WHAT YOU WANT TO KNOW.
Look for M8 in "METRIC COARSE THREADS" for the tapping drill this is 6.8mm OR on the page headed I.S.O and I.S.O METRIC FINE THREADS IN M.M where the M8 FINE tapping drill is 7mm then IF you bothered to look on the page HEADED STANDARD DRILL SIZES AND DECIMAL EQUIVALENTS 17/64 inch nearest drill for M8 coarse and 9/32 nearest size drill for M8 fine
SIMPLES as Alexander Meercat would say
yeah right after you create a microsoft account and sign in.. no thanks 🙂
