Inventor General
Active Contributor
gordon.rogers
Message 1 of 2 (311 Views)
Mass properties will not display in text box.
311 Views, 1 Replies
07-09-2012 02:06 PM
I'm having trouble getting mass properties of an assembly to display in an .idw.  I've tried it 2 diffent ways, custom properties-model "Totalmass" where I type the mass and physical properties-model "mass" where it's automatic with update.. Nothing shows, not even N/A, but in another idw (different assembly) it works. Both text boxes are saved within a sketch that is part of a template. Both idw's use the same template. If I place text on the drawing it self it works. Any suggestions would be great before I pull all my hair out.
IV 2012
Vault Collaboration 2012
Valued Mentor
Rich.O.3d
Message 2 of 2 (305 Views)
Re: Mass properties will not display in text box.
07-09-2012 03:12 PM in reply to: gordon.rogers
the sketch has to be associated with a view to pick up the model data.
if the sketch is simply on the sheet, you will only be able to reference drawing properties
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
