Inventor General
Active Contributor
nickhowe
Message 1 of 6 (201 Views)
Accepted Solution
Mass custom Iprop modification
201 Views, 5 Replies
05-18-2012 01:30 AM
Is there any easy way of adding custom Iprops to previously created parts and assemblies? A macro or something that could set up additional lines without having to go in and type them out all the time?
Please save me wearing this keyboard out! You're my only hope!
Cheers
Nick
*Expert Elite*
MariaManuela
Message 2 of 6 (195 Views)
Re: Mass custom Iprop modification
05-18-2012 02:40 AM in reply to: nickhowe
Hi Nick
Go to Design Assistant and get Copy Design Properties tool.
You can also check in http://apps.exchange.autodesk.com/ for any app to do the same.
Maria Manuela Pinho
Application Specialist
Cadtech / Asidek - Autodesk Gold Partner
Autodesk Inventor Professional 2015 | Lenovo W520
Active Contributor
nickhowe
Message 3 of 6 (184 Views)
05-18-2012 03:53 AM in reply to: MariaManuela
Perfect!! Thanks!!
*Expert Elite*
PaulMunford
Message 4 of 6 (170 Views)
05-18-2012 08:02 AM in reply to: nickhowe
Don't forget that addign a custom column to your BOM will add a custom iProperty to all the parts in the assembly.
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
*Expert Elite*
harco
Message 5 of 6 (152 Views)
05-19-2012 04:47 AM in reply to: nickhowe
edit: Sorry, Paul has just said this.:smileyembarrassed:
You can also create a dummy assembly, pull in all the parts & assemblies you want to edit, then use BOM editor and RMB on column to add column iproperty to all items.
This will batch copy the iproperty field and if you want the same value in many fields it's easy to copy and paste cells as in excel.
*Expert Elite*
PaulMunford
Message 6 of 6 (144 Views)
05-19-2012 01:02 PM in reply to: harco
OK, but you said it better! :smileyhappy:
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
