Is there any easy way of adding custom Iprops to previously created parts and assemblies? A macro or something that could set up additional lines without having to go in and type them out all the time?
Please save me wearing this keyboard out! You're my only hope!
Cheers
Nick
Solved by PaulMunford. Go to Solution.
Solved by nickhowe. Go to Solution.
Solved by MariaManuela. Go to Solution.
Hi Nick
Go to Design Assistant and get Copy Design Properties tool.
You can also check in http://apps.exchange.autodesk.com/ for any app to do the same.
edit: Sorry, Paul has just said this.
You can also create a dummy assembly, pull in all the parts & assemblies you want to edit, then use BOM editor and RMB on column to add column iproperty to all items.
This will batch copy the iproperty field and if you want the same value in many fields it's easy to copy and paste cells as in excel.
