I have a part given to me from a customer that has ALL custom planes turned on. This file is large and has many assemblies, part, sub assy's.... too much to go thru one at a time. Can I turn all 'plane views' off at once? Why? Because I find it messy... no other reason.
tks
Solved by cwhetten. Go to Solution.
On the View tab, Object Visibility:
Uncheck any of the types you don't want to see, or uncheck "All Workfeatures" to turn them all off.
(Ignore the green box in the image above.)
Cameron Whetten
Inventor 2012
Please click "Accept as Solution" if this response answers your question.
Not easily, possible with iLogic, one may be able to turn of the visibility of each work plane in a IAM or IPT file. Normally one just turns off the Work Plane visibility within Inventor from the "View" tab.
