I recently asked for help to set the mass calculation accuracy to 'VeryHigh' when doing calculations in iLogic.
I asked for the iLogic equivalent to the VBA term:
' Set the accuracy to VeryHigh.
oMassProps.Accuracy = k_VeryHigh
and was provided with:
oMassProps.Accuracy = 24580 'k_VeryHigh=24580
However, I believe that the value 24580 is actually equivalent to k_Medium.
Can somebody please confirm the iLogic equivalent value of k_VeryHigh.
Many Thanks,
Nick
p.s.
Original post:
Hi Mike,
Many thanks for the swift response.
I have my suspicions that iLogic does not respond to the numerical input, or there is a slight programming error, as through my (and others) testing, using 24580 only achieves Medium accuracy.
Many thanks for the alternative method, it seems a more robust way of achieving what I am trying to do.
Having tested it, my model is now achieving the accuracy I require, and is accomplishing it in only 75 iterations, whereas yesterday it was taking over 350.
Having struggled with this project for a month now, two weeks of which solely on trying to resolve the issues caused by the mass inaccuracy, I can safely say you are my saviour. Have some kudos.
Many thanks again,
Nick
