Inventor Forum
Manage ipart configurations inside assembly table
2 REPLIES 2
330 Views, 2 Replies
Basically I need to have 2 configurations of an assembly. These assemblies are identical except there is one part that will vary within them. What is the best method to take in doing this can be done in a table I would think but I need some guidance. Eventually I would like to be able to drive an assembly with multiple part configurations and suppressing and unsuppressing of parts from a table however this is my starting spot.
Any feed back is appreciated.
Thanks!
2 REPLIES 2
Cadmanto
Create your ipart factory.  Then insert it into your assembly.
Once in place then create the factory in the assembly.  In the table under the
component select the "Table replace" selection under the part.
This will allow you to toggle between each ipart within the table.
Hope this helps you.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: Cadmanto
Thanks thats what I was looking for!
