What are the best ways for speeding up iLogic routines? Can Inventor updating or re-calculation be suppressed while the iLogic code is running? Does ScreenUpdating = False accomplish this?
What other tips do users have for improving their iLogic code efficiency and speed?
Steve
One thing you can do to speed up a rule is to turn on Defer Updates in the beginning of the rule, and then turn it back off at the end of the rule. This will make it so Inventor will not try to update anything until after the rule is run. The only problem is if you are already using defer updates in the file, then you will get an error.
Here is the code.
Beginning of Rule
ThisApplication.AssemblyOptions.DeferUpdate = True
End of rule
ThisApplication.AssemblyOptions.DeferUpdate = False
Good morning!
I´m trying to get a pdf file for each sheet in my inventor drawing using this code in iLogic, I know it can works better but I´m not that good at programing, I make my code changing other codes I saw in the forum and this code actually works fine but I would like to make it faster, (maybe using codes from de pdfcreator) If you can help me making it faster and if is possible open the drawing model and run a macro in the assembly document referenced I would really apreciate it.
My rule runs after changing my user parameter called RELEASE from NO to YES and my code is :
'start of ilogic rule
Try
If RELEASE="YES" Then
ThisApplication.ScreenUpdating = False
WorkSpacePath = ThisDoc.WorkspacePath()
conextension = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
modelName = Left(conextension, Len(conextension) - 3)
System.IO.Directory.CreateDirectory( WorkSpacePath & "\4.0_RELEASE INFO\" & modelName & "\PDF")
PDFPath= WorkSpacePath & "\4.0_RELEASE INFO\" & modelName & "\PDF"
System.IO.Directory.CreateDirectory( WorkSpacePath & "\4.0_RELEASE INFO\" & modelName & "\DWG")
DWGPath = WorkSpacePath & "\4.0_RELEASE INFO\" & modelName & "\DWG"
COMODIN = ThisDoc.FileName(False) 'without extension
G = Len(ThisDoc.FileName)
SC=50
ThisDoc.Document.SaveAs( DWGPath & "\" & (".dwg"), True)
For Each oSheet In ThisApplication.ActiveDocument.Sheets
ActiveSheet = ThisDrawing.Sheet(oSheet.Name)
A = ActiveSheet.Name
B = Right(A,1)
C = Val(B)
H = Len(ActiveSheet.Name)
J = H-G
If C=1 And SC=50 Then 'ES EL KS NO LLEVA NUMERO FINAL
ThisDoc.Document.SaveAs(PDFPath & "\" & COMODIN & (".pdf"), True)
SC = SC + 1
ElseIf J > 7 Then 'ES UN OPP POR LO TANTO OCUPA 2 CIFRAS
ThisDoc.Document.SaveAs(PDFPath & "\" & COMODIN & "-" & UNIT & SC & "-" & UNIT & SC+1 & (".pdf"), True)
SC = SC + 2
Else
ThisDoc.Document.SaveAs(PDFPath & "\" & COMODIN & "-" & UNIT & SC & (".pdf"), True)
SC = SC + 1
Next
ThisApplication.ActiveDocument.Sheets.Item(1).Activate
ThisApplication.ScreenUpdating = True
InventorVb.DocumentUpdate()
RELEASE = "NO"
MessageBox.Show("RELEASE COMPLETED", "NOTIFICATION")
Catch ex As Exception
'if some error occurs then this code will be executed
ThisApplication.UserInterfaceManager.UserInteractionDisabled = False
Beep()
MsgBox("Error info: " & vbNewLine & ex.ToString)
End Try
'end of ilogic rule
