Inventor Forum
Making a sheet Metal plate that follow a surface
3 REPLIES 3
hakjon73
417 Views, 3 Replies
Hello
How do you most easily do a sheet metal plate that needs to follow a surface?
L1 is less than L2, and a radius of the plate?
Grateful for answers
In Inventor 2012
hakjon
3 REPLIES 3
CCarreiras
in reply to: hakjon73
Hi!
You can use the Tool "Thickness"; apply in the surface to create the  sheet metal solid.
The thickness value you will input in that operation have to be the same value as the "sheet metal rules" Thickness value, if not the part will not flat.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CCarreiras
hakjon73
in reply to: CCarreiras
Hello!
Thanks for your answer, but i don understand you, i try to describe my
problem/question in a new pdf
/H?kan
hakjon
mcgyvr
hakjon,
See the help files for how to use the "thicken/offset" button on the model tab.
