Inventor General
New Member
Message 1 of 4 (183 Views)
Making a sheet Metal plate that follow a surface
183 Views, 3 Replies
09-18-2013 11:50 PM
Hello
How do you most easily do a sheet metal plate that needs to follow a surface?
L1 is less than L2, and a radius of the plate?
Grateful for answers
In Inventor 2012
hakjon
Distinguished Mentor
Message 2 of 4 (160 Views)
Re: Making a sheet Metal plate that follow a surface
09-19-2013 02:25 AM in reply to: hakjon73
Hi!
You can use the Tool "Thickness"; apply in the surface to create the  sheet metal solid.
The thickness value you will input in that operation have to be the same value as the "sheet metal rules" Thickness value, if not the part will not flat.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Factory Design Suite Ultimate 2014
Autodesk Simulation Mechanical
Autodesk Simulation CFD
Windows 7
New Member
Message 3 of 4 (109 Views)
09-24-2013 05:14 AM in reply to: carloscarreiras8703
Hello!
Thanks for your answer, but i don understand you, i try to describe my
problem/question in a new pdf
/H?kan
hakjon
*Expert Elite*
mcgyvr
Message 4 of 4 (90 Views)
09-24-2013 06:01 AM in reply to: hakjon73
hakjon,
See the help files for how to use the "thicken/offset" button on the model tab.
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2014 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
