Hello
How do you most easily do a sheet metal plate that needs to follow a surface?
L1 is less than L2, and a radius of the plate?
Grateful for answers
In Inventor 2012
Hi!
You can use the Tool "Thickness"; apply in the surface to create the sheet metal solid.
The thickness value you will input in that operation have to be the same value as the "sheet metal rules" Thickness value, if not the part will not flat.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
hakjon,
See the help files for how to use the "thicken/offset" button on the model tab.
