Inventor General
New Member
caleb.leftwich93
Message 1 of 14 (1,280 Views)
Accepted Solution
Making a rectangular spring
1280 Views, 13 Replies
05-02-2012 12:44 PM
I have to make a spring for an engineering class I have yet me nor the teacher know how to make a rectangular spring. So please help me try to make it!
*Expert Elite*
JDMather
Message 2 of 14 (1,264 Views)
Re: Making a rectangular spring
05-02-2012 01:05 PM in reply to: caleb.leftwich93
3d intersection between helix surface and extuded surface
then sweep
attach your attempt here for further instruction.
I recommend that your teacher go through ALL of the tutorials/papers in my signature and especially the Knot tutorial.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
Curtis_Waguespack
Message 3 of 14 (1,258 Views)
05-02-2012 01:08 PM in reply to: caleb.leftwich93
Hi caleb.leftwich93,
Here's an example file that you can look at to see how it's done.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
JDMather
Message 4 of 14 (1,243 Views)
05-02-2012 01:27 PM in reply to: caleb.leftwich93
Here is another example with subtle differences - the key difference is the swept circle is on a plane perpendicular to the start point of the path to ensure the wire cross section is round.
The example isn't perfect using this helxi intersection method - but should be close enough.
If you need closer to perfect - post back and someone will suggest a slightly different intersection for the path.
Member
DerekRoes
Message 5 of 14 (251 Views)
04-30-2014 08:22 AM in reply to: JDMather
I know this is an old thread but I am drawing basically the same thing right now and am having some problems.
I used the file you posted but your lines are not straight. All of the lines going vertically (they are slanted I know, but essentially vertical) are bent in the middle instead of being straight. Is there a way to correct this?
Thank you.
*Expert Elite*
JDMather
Message 6 of 14 (246 Views)
04-30-2014 09:23 AM in reply to: DerekRoes
Something like this?
Member
DerekRoes
Message 7 of 14 (228 Views)
04-30-2014 10:19 AM in reply to: JDMather
Sorry, I am using 2012 so I cant open it.
Member
DerekRoes
Message 8 of 14 (198 Views)
04-30-2014 11:33 AM in reply to: JDMather
If I use a small pitch the transition between bends is straight but if I stretch the pitch out, it distorts the wire.
*Expert Elite*
JDMather
Message 9 of 14 (193 Views)
04-30-2014 11:38 AM in reply to: DerekRoes
I attached an example with straight lines - but you did not indicate in your problem description that you are using an older version of Inventor.
*Expert Elite*
JDMather
Message 10 of 14 (190 Views)
04-30-2014 11:40 AM in reply to: JDMather
the 2d sketch
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
