Inventor General
New Member
Message 1 of 4 (992 Views)
Making a rectangular spring
992 Views, 3 Replies
05-02-2012 12:44 PM
I have to make a spring for an engineering class I have yet me nor the teacher know how to make a rectangular spring. So please help me try to make it!
Message 2 of 4 (976 Views)
Re: Making a rectangular spring
05-02-2012 01:05 PM in reply to: caleb.leftwich93
3d intersection between helix surface and extuded surface
then sweep
attach your attempt here for further instruction.
I recommend that your teacher go through ALL of the tutorials/papers in my signature and especially the Knot tutorial.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Curtis_Waguespack
Message 3 of 4 (970 Views)
05-02-2012 01:08 PM in reply to: caleb.leftwich93
Hi caleb.leftwich93,
Here's an example file that you can look at to see how it's done.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 4 of 4 (955 Views)
05-02-2012 01:27 PM in reply to: caleb.leftwich93
Here is another example with subtle differences - the key difference is the swept circle is on a plane perpendicular to the start point of the path to ensure the wire cross section is round.
The example isn't perfect using this helxi intersection method - but should be close enough.
If you need closer to perfect - post back and someone will suggest a slightly different intersection for the path.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
