Inventor General
Member
Message 1 of 6 (155 Views)
Making a mold or inverting a part
155 Views, 5 Replies
01-25-2014 06:35 AM
     My Maker Space group does a lot of robot building and we like, when we can, to 3D print things like motor mounts and brackets.
     We are concerned that one potential motor mount will not be strong enough and would like to 3D mold the mount "around" portions of the motor to add more suppport.
    We love in 2D where you can easily (and thank you very much by the way) project geometry onto the new part you're creating.  Is there a way to do the same thing in 3D, so that we don't have to spend a lot of time adding and extruding small areas to meet the motor?
   Sort of like if we could invert the motor, take elements of that surface and 3D print them.
Doc
*Expert Elite*
Message 2 of 6 (135 Views)
Re: Making a mold or inverting a part
01-27-2014 10:09 AM in reply to: docdavies2005
Sounds like you want to Thicken/Offset as a surface body and the Thicken as a new solid body.
Attach your file here if you can't figure it out.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Member
Message 3 of 6 (97 Views)
01-29-2014 03:11 AM in reply to: JDMather
Dear Dr. Mather,
Thanks for the response!  We're snowed into day will school, and therefore FRC robotics cancelled.
 I'll try your suggestion.  I've successfully used off-set in 2D drawings, didn't know it worked in 3D.
Doc
FRC #2106
*Expert Elite*
Message 4 of 6 (92 Views)
01-29-2014 03:52 AM in reply to: docdavies2005
Depending on what you are doing - Move Face might be another option.
*Expert Elite*
LT.Rusty
Message 5 of 6 (78 Views)
01-29-2014 09:07 AM in reply to: JDMather
Hmmm ... it's been a while since I read Revelations, but isn't JD Mather suggesting the use of Move Face sandwiched in there with the signs of the apocalypse somewhere between the rains of fire and the seas of blood?
___________________________________________________________
Product Design Suite Ultimate 2013, 2014
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / 2xRadeonHD 4870 in CrossfireX
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
*Expert Elite*
Message 6 of 6 (75 Views)
01-29-2014 09:10 AM in reply to: LT.Rusty
I should have emphasized might.
:smileyvery-happy:
Move Face is (almost) always not the best solution.
Frankly, I did feel the earth shake a bit when I typed that out yesterday.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
