Inventor General
New Member
simons.jason
Message 1 of 3 (125 Views)
Making a flat projection from a loft
125 Views, 2 Replies
05-01-2012 11:57 AM
Please excuse the fact that this may be more simple than I am making it, but I have been working with inventor for a couple months. I am still getting the hang of it.
Anyhow, I made this part, which is a loft consisting of five symetric squares. I plan on laser cutting each side, which would be exactly the same.
I can't seem to figure out how to make a flat projection of one of the sides. I have tried in sheet metal, but I don't use that feature in my line of work.
Any help would be appreciated!
Jason
Employee
Message 2 of 3 (116 Views)
Re: Making a flat projection from a loft
05-01-2012 01:06 PM in reply to: simons.jason
Hi! Inventor is capable of unfolding certain spline geometry. Unfortunately, the one you created using Loft is not supported, while Lofted Flange only supports two sections.
There might be other ways to do it but I have found a way to create the desirable geometry with relatively few features. Please take a look at attached part. Let me know if you have any question.
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Autodesk, Inc.
New Member
simons.jason
Message 3 of 3 (114 Views)
05-01-2012 01:23 PM in reply to: johnsonshiue
Thanks, That is exactly what I was looking for!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
