Inventor Forum
Making a Sheet Metal Punch
21 REPLIES 21
Message 1 of 22
DougDR
1493 Views, 21 Replies
Hi all
I have made some punches for sheet metal and this one seems to be simple but it has me stumb. Please help.
Its 50mm in Dia a 5mm lip a 28mm outside rad cone and a depth inside of =/- 8.5mm then there is a 12mm hole
Doug Davey
Mechanical Designer
Tags (2)
21 REPLIES 21
Message 21 of 22
DougDR
in reply to: JDMather
to JDMather . Thank you so much for helping. Great tech.Thanks again
Doug Davey
Mechanical Designer
Message 22 of 22
adsk_loren
in reply to: DougDR
Charlie Bliss has several complex punches on his site that include the source part. You should download the parts and use the End of Part marker to step through each sketch and feature.
http://www.cbliss.com/inventor/iFeatures/index.htm
Loren
