Inventor Forum
M12 ISO 7413 Hex Nut?? - Library
6 REPLIES 6
546 Views, 6 Replies
Can someone try inserting one of these from the library and see if it has a
1.2 mm hole instead of a 12mm hole!!!
How poor is that????
Cheers,
--Rob Singlehurst
6 REPLIES 6
Do you have sp1 ? Cause I had this problem prior to sp1, but it is fine
now....hmm did`nt you get threads visible in nuts as well, pre sp1 or do I
remember wrong ???
If you have sp1, maybe you allready have used this particualar nut, and
therefor it opens the pre sp1 one...maybe ? not even shure if it works that
way.
Jørgen
"Rob Singlehurst" wrote in message
news:AF47054FB714CE23A6C2572D6775475C@in.WebX.maYIadrTaRb...
a
> Cheers,
> --Rob Singlehurst
Yes, sorry the threads are visible. But SP1 on this morning and hadn't
needed that part before SP1. I haven't got an old 5.3 one in StandardParts.
I had altered threads.xls but have put the original back and it does the
same. I may try rebooting, see if it makes any difference.
Cheers,
--Rob Singlehurst
"JGH" wrote in message
news:B0AD6B1BAC34A4777CE4208BFE2238A2@in.WebX.maYIadrTaRb...
I
> remember wrong ???
that
> way.
> Jørgen
has
> a
> > Cheers,
> > --Rob Singlehurst
I have since sorted this out by deleting all of the local.ISO.whatever.ipt
files in the workgroup search path. Does anyone know why these are not put
in the StandardParts folder like they used to be. The only way I can work
like I used to is then move the parts into the StandardParts folder and then
open my original assembly and point to the correct folder.
Cheers,
--Rob Singlehurst
news:1531129D0A51F5428587F00A034F666E@in.WebX.maYIadrTaRb...
StandardParts.
> Cheers,
> --Rob Singlehurst
do
> I
> > remember wrong ???
> that
> > way.
> > Jørgen
> has
> > a
> > > Cheers,
> > > --Rob Singlehurst
Another thing!!
Why didn't they keep the same naming convention for the standard so it's
easy to see which part is which from the file names??
news:99691795E3F86345ABB1E482798B41ED@in.WebX.maYIadrTaRb...
put
then
> Cheers,
> --Rob Singlehurst
> StandardParts.
> > Cheers,
> > --Rob Singlehurst
fine
> do
> > I
> > > remember wrong ???
and
> > that
> > > way.
> > > Jørgen
it
> > has
> > > a
> > > > Cheers,
> > > > --Rob Singlehurst
Not sure, but try this, In the library browser choose Conigure, dbl click
server name/edit- Choose storage Location and try one of the other options
(not parent assembly)...maybe ? I guess if you have added a library
searchpath you might get that listet or something ?
Jørgen
put
then
> Cheers,
> --Rob Singlehurst
> StandardParts.
> > Cheers,
> > --Rob Singlehurst
fine
> do
> > I
> > > remember wrong ???
and
> > that
> > > way.
> > > Jørgen
it
> > has
> > > a
> > > > Cheers,
> > > > --Rob Singlehurst
Thanks Jorgen, (not sure how to get the funny o)
That's what I wanted! Pretty about the file names though.
Cheers,
--Rob Singlehurst
news:EACB03991E410DF81A32FCB58300D78C@in.WebX.maYIadrTaRb...
> Jørgen
> put
work
> then
> > Cheers,
> > --Rob Singlehurst
hadn't
> > StandardParts.
the
> > > Cheers,
> > > --Rob Singlehurst
> fine
or
> > do
> > > I
> > > > remember wrong ???
> and
works
> > > that
> > > > way.
> > > > Jørgen
> it
> > > has
> > > > a
> > > > > Cheers,
> > > > > --Rob Singlehurst
