I found it! I just cranked the resolution up to 1600x1200 on both monitors
and it was hiding over on an edge. I didn't get a chance to try changing the
reg values to 500,500. Not sure what version I have but it seems to work
fine otherwise. Maybe I should download the latest. Thanks.
"Kent Keller" wrote in message
news:40fc4390$1_1@newsprd01...
> Actually if you had the latest version it "should" recognize resolution
> changes and put itself back on the screen.
> Go to "HKEY_CURRENT_USER\Software\VB and VBA Program
> Settings\KWiKViews\Settings" in the registry and set to top and left to
500
> each should do it. Of course all the typical warnings about editing the
> registry.......
> Kent Keller
> Autodesk Discussion Forum Facilitator
> "John" wrote in message
news:40fc390b$1_2@newsprd01...
> > After unplugging monitors, running the system at home as administrator,
> and
> > reconnecting the monitors back at work, I've got KwikViews totally
> confused.
> > I can't find it, but it's on. It's not over on the other monitor either.
> Is
> > there some way to reset the registry settings for Kwikviews so it'll
come
> > back.
> > Sniff, sniff - I miss my Kwikviews. ;(
