After making some changes to my dual monitor setup my New... dialog box isn't appearing on either monitor. It's there but offscreen.
I've tried rebooting, changing back to my previous monitor setup and statring inventor maximized and minimized on both monitors. Also tried loading a UserCustomization.xml..
Can I set the dialog position in the registry or is there another way to reset it's position?
I'm running 2008 SP3 on XP 32bit SP3.
Thanks!
Solved by ampster402. Go to Solution.
you can try moving the window with your keyboard;
1. press and hold the alt button then spacebar, then release both keys.
2. press the m key
3. use arrow keys to move window.
Hint, try this with a visible, non-maximized window first to see how this works.
Also, you may have to try this multiple times until you figure out what direction the window needs to move.
good luck!
That worked perfectly. Thanks for the quick response!
