My question is there functionality to break a part that is 60' and have it deatiled on two seperate sheets? The problem is that i do not know of any functionality of doing this in inventor? Other than create two seperate plan views and crop the view to show only what i want on sheet one. Then do this process again on sheet two correct? Then I need to go in and manually add the matchline into each drawing with a sketch line? Does this sound right? Do any of you have suggestions and comments for me? Thanks
If I wanted to use one end for a reference I would use the whole part and insert a break in the relavant area.
I would then reference the end probably using an Ordinate set for all lengths.
The end closest to the reference end gets broken past 1/2 way and a total length put in just because.
Thanks for the help. What would yall do if you needed to do the same thing in two different idw but reference the same plan view?
@Anonymous wrote:Thanks for the help. What would yall do if you needed to do the same thing in two different idw but reference the same plan view?
Don't really understand that question. If you have 2 different IDW files you can bring the same assembly into both of them in whatever view configuration you want whether plan, right left etc.
Have used 3 sheets before for a long complicated assy, just use the view representation you want and make sure the update box is clicked.
