Inventor General
tbitting
Message 1 of 5 (142 Views)
Accepted Solution
Lofting with rails
142 Views, 4 Replies
04-16-2012 12:34 PM
Hi all,
I have a part that I'm trying to loft using 3d sketches for the rails will this work? Everything is fine till I try to add the rails, As you can see the loft works with out the rails.
Thanks for looking
Tim Bitting
Windows 7 x64
IV 2012
*Expert Elite*
JDMather
Message 2 of 5 (131 Views)
Re: Lofting with rails
04-16-2012 01:30 PM in reply to: tbitting
Your rail curves are not smooth (tangent) as indicated by the error message.
Therefore either add appropriate fillets or do a spline if that gets your design intent
or
if your design intent is straight lines as you have your rails - then simply do two lofts.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
tbitting
Message 3 of 5 (123 Views)
04-16-2012 01:46 PM in reply to: JDMather
Thanks JD. that will work for what I need on this. But if I need to, where would I add fillets?
Tim Bitting
Windows 7 x64
IV 2012
*Expert Elite*
JDMather
Message 4 of 5 (118 Views)
04-16-2012 01:55 PM in reply to: tbitting
At the intersections of the  lines in  your 3D sketch. (Bends in 3D sketch)
But actually - I almost never ever create a 3D sketch as you have.
Nearly all of my 3D sketches are a result of Intersection Curve of 2D sketches.
Much easier to control and edit.
So, I would have had a Front and Side (in your case) 2D sketches with fillet constrained in one or the other (depending on design intent) to Sketch8, then found the 3D intersecting curve.
Yours is a simpler case of the 3D sketch in the Vacuum tutorial in my signature.
tbitting
Message 5 of 5 (107 Views)
04-16-2012 03:46 PM in reply to: JDMather
Ok I've seen the vacuum  part before, I'll have to go back and review, it's been awhile.
Thanks again.
Tim Bitting
Windows 7 x64
IV 2012
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
