Inventor General
Member
daniel.pinsonneault
Message 11 of 14 (105 Views)
Re: Lofted surface transition
05-02-2012 03:08 PM in reply to: daniel.pinsonneault
Thank you very much M. Mather
I agree with you about the simplicity of the sketchs. This part was originally modeled with Catia and I have tried to use the same dimensioning that I found on the original drawing.
Your solution #1 is more acceptable to me because I need a shell thickness of .05 inch. In your rev. 1, I am unable to create a shell as low as .001 inch.
I think it would be simpler if I had better control of the lofted surface in my original IPT file.
Daniel P.
Inventor 2012 sp1
Windows 7 64 bits
8Mb Ram
*Expert Elite*
JDMather
Message 12 of 14 (100 Views)
05-02-2012 03:37 PM in reply to: daniel.pinsonneault
I'm sure if you used rails you could get better results and should be able to shell to any thickness down to where the fillets (which I would do as fillet features, rather than sketch fillets) near zero radius.
Give it another try and if you don't get better results I will see if I can find time to improve the part.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
daniel.pinsonneault
Message 13 of 14 (94 Views)
05-02-2012 07:25 PM in reply to: JDMather
Thank you,
I will try with your recommandations this weekend and I will come back with the results.
Member
daniel.pinsonneault
Message 14 of 14 (72 Views)
Re: Lofted surface transition SOLVED
05-10-2012 08:02 AM in reply to: daniel.pinsonneault
Finally got it with JD's recommandations.
Thank you very much.
Daniel P.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
