Inventor Forum
Loft with multiple openings
5 REPLIES 5
nick.jeuris.hotmail
1296 Views, 5 Replies
Hi
I was wondering if it is possible to make a surface loft go from 1 square section to 2 round sections.
So 1 ingoing section en 2 outgoing sections.
I've attached a simple drawing.
Many thanks in advance!
Nick
5 REPLIES 5
I think it may be possible to do two seperate lofts as surfaces, then once these surfaces exist, do a sculpt to create a solid.
Let me know if you need me to explain in more detail.
Edit: I have had a bit of an experiment with it but so far I can't seem to be able to get the sculpt to compute.  I think the surfaces need to be merged together somehow first. I have tried using 'stich' but this didn't seem to solve the problem.
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
fakeru
in reply to: waynehelley
Wayne Helley,
I suggest you make the 2 lofts in solid. Then delete the 3 faces and you will get a surface.
Something like that:
Autodesk Inventor 2015 Certified Professional
Hi Nick,
It’s not too difficult to loft square to 2 rounds, but the transition is not really pretty,
It would look nicer if the square edges had radii if allowable.
Just keep in mind the topology of the loft.
Keep loft edges to the same edge count, (i.e. not 1 edge to 3) etc...
Cheers
Mark
Cheers
Mark
Inventor 2018, 3DS Max 2018, Vault 2018
Thanks for the quick answers.
I found a method which gives a satisfactory result.
First I made 2 lofts, next I deleted the faces in between the lofts and finally, I patched the 2 lofts together.
I have attached a screenshot of the result.
Thanks everyone for the replies!
If you want this to be a true sheet metal transition which could be flattened, you would have to make two halves like the attached.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
