Inventor Forum
Loft command giving me problems
2 REPLIES 2
Mesainc1
2079 Views, 2 Replies
I am trying to use the loft command to go from Sketch 3 to Sketch 4, but with the output on solid, it gives me this error. "The attempted operation had problems trimming and discarding faces. Try with different inputs."
I am using Inventor 2012 professional. The loft commands I am using are "Join", "Rails" "Solid Output"
2 REPLIES 2
EScales
in reply to: Mesainc1
It won't work because you multiple loops in each sketch.  If you edit the sketches and changes the inner loops to construction lines, it will work.  You'll get a solid loft and then you can use the shell command to hollow out the inside and maintain your .100" wall thickness.
Mesainc1
in reply to: EScales
That worked great. Thank you very much.
