Is it possible to loft a shape which includes a hole or a section missing?
I am trying to loft the following shape but it doesn't seem to work with the missing section in the middle. Currently the 2 sketches are the same but in the actual design they aren't. i wanted to test if it would work with the same sketches but it doesn't.
If it is not possible what would be the easiest solution?
I want a curved profile to the edge, I just haven't included it. I thought loft would be the easiest way but maybe it isn't.
I'm trying to achieve a similar profile to what is in this image.
Loft in two steps.
Step one for the outer shape.
Step 2 to cut the holes.
Attach your file here if you can't figure it out.
The CADWhisperer YouTube Channel
to elaborate on JD's post - Inventor cannot loft a profile with a void in the middle to create a lofted tube. But I can loft the exterior face and then loft the interior face (with a cut) to create what is desired in 2 steps.
Assuming you are using rails with your loft (instead of centre-line), to give you a curve/bulge to the shape along the length of the loft, then you're probably going to want a set of rails for both the inner and outer profile to get them to match.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
