workstation with internet connection does'nt have problem to launch Inventor (2011).
Those who don't have a internet connection (browser over the web) it takes up to 2 min to launch the software.
When I unplug the network cable, it takes less then 20 sec to boot up.
When I try with a active internet connection it works fine.
It would be simple to let them the internet connection, but it is not my call. Then I'm trying to find a way to stop inventor to sneek over the web at the bootup.
Any chance someone here can help ?
Hi dchaput,
I suspect the Communication Center is the issue:
Registry Entry to disable it, note that Inventor 2011 is RegistryVersion15.0
I hope this helps.
Curtis
Thanks Curtis,
I did turn off the communication center by following the procedure you provided.
I still have to wait upto 2 min to launch the software.
Dany
Have you done a search of this forum for this problem? I recall this coming up before.
Here's a link to one such thread: http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2012-loading-SLOW-when-attached-to-network...
Hi Mike,
Yes I did a search before asking the question. The solution proposed on the others posts did'nt solve the problem on our workstations.
One way or the other, I will find a workaround
Dany
Are you aware of tools like Process Monitor, which lets you monitor what the computer is doing? This should get you narrowed in on where the delays are happening.
