Inventor Forum
Linking excel sheet to drawing file (idw)
2 REPLIES 2
477 Views, 2 Replies
Hi all
I am trying to link excel file to drawing file (idw), but couldn't succeed. Is it possible? if yes please share your knowledge
Looking for your help
2 REPLIES 2
CCarreiras
Hi!
If you are thinking about place one excel chart in the drawing, yes, it's possible, BUT, it will not be associative, if you change the excel, it doesn't update in the drawing.
You can link the excel file (not embeded ) to the drawing file, in that case, if you change the excel file, it will be updated in the drawink link, just because that, it's just a link.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Paul-Mason
in reply to: CCarreiras
In addition to what carloscarreiras8703 has said it is also a good practice to keep the spreadsheet file in the same folder that as the project, it make it much easier to find for both you and Inventor.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
